发表于 2025-4-18 13:15:39 |显示全部楼层
With the gradual rollout of the Wi-Fi 7 standard, Qualcomm has introduced a series of Wi-Fi 7-capable SoC solutions. Among them, the IPQ5424 and IPQ5322 are two standout chips positioned for the mid-to-high-end networking market. Although both belong to the Qualcomm Network Pro platform and support core Wi-Fi 7 technologies, they differ significantly in architecture, performance, interface capabilities, and target applications. This article provides a comprehensive comparison to help guide product selection and system design.
1. Core Architecture & Processing Performance[td]
FeatureIPQ5424IPQ5322
CPUQuad-core Cortex-A73Quad-core Cortex-A53
Clock SpeedUp to 2.2GHzUp to 1.5GHz
Process Node6nm / 7nm FinFET14nm
PlatformNetwork Pro 620 SeriesNetwork Pro 420 Series
The IPQ5424, with its more advanced Cortex-A73 cores and higher clock speed, significantly outperforms the IPQ5322, which uses power-efficient Cortex-A53 cores. This makes the IPQ5424 better suited for high-throughput, high-concurrency network environments.
2. Wi-Fi Capabilities[td]
Wi-Fi StandardWi-Fi 7Wi-Fi 7
Frequency BandsDual-band (2.4G + 5G)Dual-band (2.4G + 5G)
MLO SupportSupportedSupported
Max PHY Throughput~5.8+ Gbps (depends on front-end)~3.6 Gbps (depends on front-end)
Common RF PairingsQCN6274 / QCN9274QCN6224 / QCN6274
Both chips support key Wi-Fi 7 features such as MLO (Multi-Link Operation), 4096-QAM, and Multi-RU, but the IPQ5424 can deliver higher throughput when paired with higher-end front-end chips.
3. Interface & Expansion Capabilities[td]
Interface TypeIPQ5424IPQ5322
PCIe Support2 x PCIe 3.01 x PCIe 2.0
Ethernet Support2.5G/1G/SGMII/RGMII1G/SGMII/RGMII
USBUSB 3.0USB 3.0
Max Ethernet Speed2.5G1G
IPQ5424 offers stronger expansion capabilities through more PCIe lanes and higher Ethernet throughput, making it suitable for devices with multiple RF modules or multi-gigabit ports.
4. Application Scenarios[td]
FeatureIPQ5424 ApplicationsIPQ5322 Applications
Target DevicesHigh-end enterprise routers, mesh hubs, outdoor APsMid-range home routers, mesh nodes, SMB APs
User DensityMedium to highLow to medium
Overall CapabilityHigh throughput and multitaskingSufficient for general usage
IPQ5424 is ideal for performance-driven commercial or industrial deployments, while IPQ5322 is tailored for cost-sensitive consumer and SOHO markets.
5. Power Consumption & Thermal Design[td]
Power ProfileHigherLower
Cooling NeedsRequires active or advanced passive coolingStandard passive cooling sufficient
Due to its higher performance, IPQ5424 requires better thermal management, while IPQ5322 is more energy-efficient and suitable for compact or fanless designs.
6. Cost Analysis[td]
Chip CostHighModerate
BOM CostHighModerate-Low
While IPQ5424 delivers superior performance, it also comes with a higher total cost. IPQ5322, on the other hand, offers a better balance between capability and affordability for mid-range designs.
7. Summary[td]
Comparison AspectIPQ5424IPQ5322
CPU PerformanceCortex-A73, high clock speedCortex-A53, energy-efficient
Process Node6nm / 7nm14nm
Wi-Fi CapabilityHigh-throughput dual-band Wi-Fi 7Moderate-throughput dual-band Wi-Fi 7
Interface SupportPCIe 3.0, 2.5G EthernetPCIe 2.0, 1G Ethernet
Application ScopeEnterprise / IndustrialHome / Small Office
Cost StructureHigherMid-range
Conclusion:
  • Choose IPQ5424 for high-performance, multi-user Wi-Fi 7 routers or enterprise-grade APs.
  • Choose IPQ5322 for affordable, power-efficient designs in the consumer and SMB markets.
If you're working on board design or chip selection and need additional reference materials—such as block diagrams, recommended RF module pairings, or performance estimates—feel free to reach out. I'd be happy to help with more in-depth guidance.
编辑:wifi6yiyi
链接:https:// juejin.cn/spost/7494172337081794597
来源:稀土掘金
著作权归编辑所有。商业转载请联系编辑获得授权,非商业转载请注明出处。
GMT+8, 2025-4-22 05:41 , Processed in 0.178193 second(s), 16 queries , Gzip On.
