亚星游戏官网-yaxin222  上等兵
注册:2016-2-261
发表于 2025-3-11 09:57:09 |显示全部楼层
(A) : Before a device try to transmit any data, it start Carrier Sensing.
(B) : If the device detect any carrier signal (i.e, some other device is using the channel), it just go back to 'Waiting' mode and would not try further carrier sensing for a BackOff Period.
(C) : Even if the carrier is not busy (i.e, even if nobody is using the channel), the device keep sensing the carrier for a certain duration (DIFS). If it detect any carrier signal during this period, it go back to 'Waiting' mode and would not try further carrier sensing for a BackOff Period.
(D) : If no carrier signal is detected for a certain period (DIFS), the device assume that the channel is clear (nobody is using the channel) and it transmit its own data.
GMT+8, 2025-3-31 10:24 , Processed in 0.099708 second(s), 16 queries , Gzip On.
