查看: 1761|回复: 2
[通信技术与资料] 基于QC平台的搜网LOG整理 [复制链接]
注册:2021-8-5
发表于 2024-12-23 19:27:58 |显示全部楼层
搜网大致流程
LTE搜网NAS层
06:31:37.338002CallManager/High[cmregprx.c2616]=CMREGPRX=FILL_SRV_REQ:srvreq0,network_selection_mode0->0,mode_pref5->5,disablemask2//callmanager发起搜网06:31:37.338002NASREG/High[reg_state.c9921]DS:SUB1=REG=CM_SERVICE_REQ//搜网请求传递到nas层06:31:37.338002NASREG/High[reg_state.c2077]DS:SUB1=REG=NEWRATprioritylistnum_items=1ScanScopetype=0,additional_infoinCM_SERVICE_REQ=0Voicedomainpref=306:31:37.338002NASREG/High[reg_sim.c7795]DS:SUB1=REG=HPLMN001-01//REG根据sim运营商制式等,进行plmn搜索06:31:37.338002NASREG/High[reg_sim.c4918]DS:SUB1=REG=FPLMNlistlength=2006:31:37.338002NASREG/High[reg_nv.c511]DS:SUB1=REG=NVreg_nv_use_rplmnact_mode_changesetto=006:31:37.338002NASREG/High[reg_nv.c516]DS:SUB1=REG=reg_nv_is_home_plmn_to_be_selcted_in_home_countryreadas=006:31:37.338002NASREG/High[reg_state.c3248]DS:SUB1=REG=CM_SERVICE_REQ-AUTOMATICtype=206:31:37.338002NASREG/High[reg_sim.c3797]DS:SUB1=REG=StoredRPLMN(1-1)06:31:37.338002NASREG/High[reg_send.c1900]DS:SUB1=REG=volte_only=006:31:37.338002NASREG/High[reg_send.c1914]DS:SUB1=REG=MMR_REG_REQPLMN(1-1)RAT(0-GSM,1-W,2-LTE,3-TDS)=2netsel0,type1grat_scan_done0trans_id35trm_timeout-1//REG找到最合适的PLMN06:31:37.338002NASMM/High[emm_rrc_if.c563]DS:SUB1EMM:SentLTE_RRC_SERVICE_REQscan_scope0,new_scan1,usetimer0,timervalue0//把PLMN信息发送到RRC06:31:37.350050LTERRC/Low[lte_rrc_csp.c25647]CSP:TryingSystemScanwithcombineACQDBlist//RRC收到后,发起扫频,优先system扫频,如果为空发起band扫频06:31:37.350050LTERRC/High[lte_rrc_llc.c1482]SentSystemScanRequest06:31:37.350050LTEML1/High[lte_ml1_sm_main.c2346]SM:SysScanReqmodule1num_sys10min_sys0early_abort0sys[0]band3earfcn1425bw25//查询到符合的频点有10个06:31:37.350050LTERRC/High[lte_rrc_csp.c6247]CSP:SentSystemScanRequestfor10systems06:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6433]SM_fs:SystemScanResults,numsystemsfound10//把10个频
点的小区信号能量强度列出来06:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn50bw50scaledenergylinear0x9b7dBm-7806:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn350bw50scaledenergylinear0x12dBm-9906:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn3590bw50scaledenergylinear0x7dBm-10306:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn1850bw100scaledenergylinear0x5dBm-10406:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn1425bw25scaledenergylinear0x2dBm-10906:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn3745bw50scaledenergylinear0x2dBm-10906:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn39148bw100scaledenergylinear0x2dBm-10906:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn38950bw100scaledenergylinear0x1dBm-11406:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn39292bw50scaledenergylinear0x1dBm-11406:31:37.731599LTEML1/High[lte_ml1_sm_fs.c6481]SM_fs:earfcn41332bw100scaledenergylinear0x0dBm-11806:31:37.731599LTERRC/High[lte_rrc_csp.c28062]CSP亚星游戏官网-yaxin222rioritizeSystemscanresultsforReqPLMN//结果返回到RRC06:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:1earfcn:50energy:-7806:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:1earfcn:350energy:-9906:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:8earfcn:3590energy:-10306:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:3earfcn:1850energy:-10406:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:3earfcn:1425energy:-10906:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:8earfcn:3745energy:-10906:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:40earfcn:39148energy:-10906:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:40earfcn:38950energy:-11406:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:40earfcn:39292energy:-11406:31:37.732002LTERRC/High[lte_rrc_csp.c28079]CSP:band:41earfcn:41332energy:-118
06:31:37.732002LTERRC/Low[lte_rrc_csp.c6465]CSP:Acqrequestedonearfcn50//优先选择能量最强小区06:31:37.732002LTERRC/High[lte_rrc_llc.c1493]SentAcqRequest//请求驻留小区06:31:37.732002LTEML1/High[lte_ml1_mgr_stm.c14927]LTE_CPHY_ACQ_REQTransid6Band1earfcn50rest_cfg0#black_cells0acq_type0acq_cell_id006:31:37.980489LTEML1/Medium[lte_ml1_mgr_stm.c19147]L1M亚星游戏官网-yaxin222TE_CPHY_CELL_SELECT_REQ//驻留小区S准则检查06:31:37.980489LTERRC/High[lte_rrc_csp.c6579]CSP:SentCellSelectionRequest06:31:37.986913LTEML1/High[lte_ml1_sm_idle.c4824]Cell(50,0)Srxlev50,rsrp-72rsrq-3qrx-132qrx_off0pmax33pcomp10//Srxlev>006:31:37.987005LTEML1/High[lte_ml1_sm_idle.c4914]Cell(50,0)Squal125,LLRSRQ-3normalizedrsrq-3q_qual-128q_qual_off0//Squal>006:31:37.987005LTEML1/Medium[lte_ml1_mgr_cphy_cnf_handlers.c1317]LTE_CPHY_CELL_SELECT_CNFStatus:0//满足S准则06:31:37.987005LTERRC/Low[lte_rrc_csp.c33260]CSP:ReceivedCellSelectCnf06:31:37.987005LTERRC/Low[lte_rrc_csp.c33424]CSP:Cellselectreqissuccess,configuring06:31:37.987005LTERRC/Low[lte_rrc_csp.c33435]CSP:Suitablecell06:31:37.987005LTERRC/Low[lte_rrc_csp.c33449]CSP亚星游戏官网-yaxin222roceedingtocamped//小区选择成功,驻留小区06:31:38.006006LTENASEMMPlainOTAOutgoingMessageAttachrequestMsg//发起随机接入06:31:38.006006UL_CCCH/RRCConnectionRequestRadioBearerID:0,Freq:50,SFN:006:31:38.207083DL_CCCH/RRCConnectionSetupRadioBearerID:0,Freq:50,SFN:5606:31:38.209020UL_DCCH/RRCConnectionSetupCompleteRadioBearerID:1,Freq:50,SFN:006:31:38.465196DL_DCCH/UECapabilityEnquiryRadioBearerID:1,Freq:50,SFN:8206:31:38.465196UL_DCCH/UECapabilityInformationRadioBearerID:1,Freq:50,SFN:006:31:38.901338DL_DCCH/SecurityModeCommandRadioBearerID:1,Freq:50,SFN:12506:31:38.902007UL_DCCH/SecurityModeCompleteRadioBearerID:1,Freq:50,SFN:0
06:31:39.026206DL_DCCH/RRCConnectionReconfigurationRadioBearerID:1,Freq:50,SFN:13
GMT+8, 2025-4-21 15:08 , Processed in 0.197555 second(s), 16 queries , Gzip On.
