注册:2024-10-8
发表于 2024-12-6 21:40:49 |显示全部楼层
HUAWEI Huawei MA5626 做端口互通
适用于308版本。
MA5626#config
MA5626(config)#vlan service-profile profile-id 1 #创建一个ID号为1的vlan配置模板
{ |profile-name }:
Command:
MA5626(config-vlan-srvprof-1)#user-bridging enable #使能二层互通功能
Info: Please use the commit command to make modifications take effect
MA5626(config-vlan-srvprof-1)#commit      #设置二层互通后需要使用commit命令使其生效
MA5626(config-vlan-srvprof-1)#quit
MA5626(config)#vlan bind service-profile 1 profile-id 1      #将vlan 1与创建的vlan模板绑定
MA5626(config-if-vlanif1)#quit
MA5626(config)#multi-service-port vlan 1 port 0/1 1-8 user-vlan untagged rx-cttr 6 tx-cttr 6 #批量增加业务虚端口
It will take several minutes, and console may timeout, please use command
idle-timeout to set time limit
Are you sure to create service virtual port(s)? (y/n)[n]:y
The number of total board in this operation: 1
The number of total service virtual port in this operation: 8
Creating start…
Creating end:
The number of total service virtual port which need be created: 8
The number of total service virtual port which have been created: 8
MA5626(config)#
%2000-01-02 14:42:18+08:00 MA5626 IFNET/2/UPDOWN亚星游戏官网-yaxin222ine protocol on the interface vlanif1 turns into UP state
MA5626(config)#interface vlanif 1 #进入vlan 1
MA5626(config-if-vlanif1)#ip address 10.0.2.4 255.255.255.0 #配置管理地址
{ |description|sub }:
Command:
ip address 192.168.1.2 255.255.255.0
GMT+8, 2025-3-12 11:36 , Processed in 0.098828 second(s), 16 queries , Gzip On.
