亚星游戏官网-yaxin222  列兵
注册:2023-4-253
发表于 2024-8-29 16:22:11 |显示全部楼层
三伍微 射频开关WiFi   GSR1370S 兼容替代SKY/RTC/KCT/Qorvo
GSR1370S: CMOS SOI SPDT Switch 0.01 – 7.2 GHz
Applications
*WLAN 802.11a/b/g/n/ac/ax networks
* ISM band radios
* Low power T/R systems
Features
*P0.1dB +32dBm typical @ +3.3V
*Low insertion loss (0.50dB @ 2.5GHz, 0.58dB @ 5.8GHz)
* High isolation (25dB @ 2.5GHz)
* Low delay, switch time: 75~125nS
* 1.5mm × 1.5mm QFN Package (MSL3, 260°C per JEDEC-J-STD-020)
Description
Using advanced switching technologies, the GSR1370S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.5 mm × 1.5 mm package. The GSR1370S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz required high power at low control voltage.
GMT+8, 2025-4-4 14:54 , Processed in 0.152170 second(s), 17 queries , Gzip On.
