注册:2015-9-4
发表于 2024-8-22 22:30:50 |显示全部楼层
HUAWEIMA5626/MA5620 EPON/GPON ONU设备恢复出厂设置密码
本文章将引导您配置HUAWEIMA5626恢复出厂设置(包括登录密码),提供MA5620、MA5626空库文件下载及《MA5620E/MA5626E EPON 远端光接入单元V800R305配置指南》
空库文件、配置指南下载地址:https://cloud.orcy.net.cn:5002/s/g6mn2yaQBZH5oHz
SecureCRT下载地址:https://www.orcy.net.cn/402.html
默认用户名:root 默认密码:mduadmin
操作步骤:
1.用串口连接线连接好设备然后打开终端App连接串口
2.打开设备电源, 当出现  Press <D> key to stop auto-boot  时按下 D 键
Platform System start … Master Core Bios Start!  Memory Data Bus Test ……………..pass.  Memory Address Bus Test …………..pass.  Press 'Ctrl+T' To Start Memory Complete Test  Trace code : 0x00000000  Copy MasterCore Bios From ROM to RAM ………… OK!  Uncompress MasterCore Bios From ROM to RAM …… OK! System Vfs init…OK The latest reboot is caused by : power off Copyright (c) 1998 - 2014 by Huawei Technologies Co.,Ltd.  All Rights Reserved. The last update date of base BIOS A is : Jul 11 2014   09:13:44 ===============================================================  BOARD INFORMATION :     CPU: ARM Integrator - Cortex A9 (ARM).  Processor  running at 400Mhz    248M bytes DDRAM, 32M bytes flash memory installed on board    Baudrate of serial channel is 9600bps    Board's LAN IP address is 10.11.104.2    Board's LAN Subnet mask is 255.255.255.0    Board's LAN MAC address is BC:3F:8F:B4:E1:8B  =============================================================== System is booting from base BIOS… Base BIOS version is 108  Press <D> key to stop auto-boot    3
3.在Main menu菜单选择1
     Main menu:     ==============================================     0    Boot from flash     1    Load files     9    Reboot system          Please enter a choice : 1
4.在SubMenu: Load files菜单选择2
SubMenu: Load files  ==============================================  0    Back to main menu  1    Download program file to flash  2    Download Data file to flash  3    Download basebios file to flash  4    Download cpld file  5    Download packet file  p    Download cold patch  l    Download any file to flash by tftp  d    Download program file to ddram  6    Download updatetool file to flash  7    Download equipment file to flash  a    Download slave core program file to NOR flash Please enter a choice :
5.此时选择0,使用串口传输
Please select load mode[default: 1 -- TFTP load mode]:  ============================================  0  Xmodem load mode  1  TFTP load mode  Q  Quit Please enter your choice:
波特率选择1,9600BPS
Please Select download speed: 1.    9600BPS 2.    19200BPS 3.    38400BPS 4.    57600BPS 5.    115200BPS Select baudrate[default : 1]:
确认选择,输入y,回车继续
You will download file by xmodem at 9600 BPS, are you sure? (y/n) [y]
6.此时设备会处在等待阶段,需要在终端App上选择发送文件,本文以SecureCRT为例
Press CTRL+C key to abort!  Waiting …CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
在CRT上选择传输->发送Xmodem
亚星游戏官网-yaxin222图1 发送Xmodem文件
在弹出的窗口选择对应设备型号的空库文件,单击Send,等待上传完成
亚星游戏官网-yaxin222图2 send空库文件
7.上传完成后,选择0,返回main menu
Starting xmodem transfer.  Press Ctrl+C to cancel. Transferring Hauwei_MA5626_database…   100%      43 KB     732 bytes/sec 00:01:01       0 Errors   44658 bytes download OK   save file to main area…..ok!  save file to spare area…..ok! SubMenu: Load files  ==============================================  0    Back to main menu  1    Download program file to flash  2    Download Data file to flash  3    Download basebios file to flash  4    Download cpld file  5    Download packet file  p    Download cold patch  l    Download any file to flash by tftp  d    Download program file to ddram  6    Download updatetool file to flash  7    Download equipment file to flash  a    Download slave core program file to NOR flash Please enter a choice :
8.在Main Menu菜单选择9,重启设备
Main Menu:  ==============================================  0    Boot program  1    Load files  9    Reboot system  debugmode            Switch debug mode  supermode            Switch super mode Please enter a choice :
9.等待设备重启
设备重启完成后,输入默认用户名root,默认密码mduadmin,即可登录系统!
GMT+8, 2025-4-21 14:58 , Processed in 0.224241 second(s), 16 queries , Gzip On.
