亚星游戏官网-yaxin222  下士
注册:2015-12-194
发表于 2024-7-14 02:10:45 |显示全部楼层
中文语言:
DongHuaNan5800#language chinese
强制成千兆口:
YiGuo6800(config-if-ten-gigabitethernet-19:3)#speed 1000
duplex full  //5800才有
[ipoe]TianLiSE1200C(config-port)#no auto-negotiate  //bras上要实行这条强制的才生效
是还的要做还:
create ethernet ring 1    》》》创建还
ethernet ring 1 primary   》》》堵塞端口
ethernet ring 1 secondary  》》》畅通端口
XiCun6800#show ethernet ring port       》》》查看环
Raisecom#commit system2 slot  9    6800升级不了倒换一下版本(版本system2要一致才行)
Raisecom#download system2 ftp 192.168.1.101 admin 123456 ISCOM6800-ZD01_ROAP_2.1.15(SP7)_20140808 slot 9
DongHuaNann6800#download system1 ftp 10.132.136.91 123456 123456 ISCOM6800-GP16_ROAP_2.60.5_20160726 slot 14 card-type gp16     GPON版本的升法
download system1 ftp 211.162.62.33 YouHua YouHua ISCOM6800_ROAP_2.41.1(SP1)_20160112 slot 14 card-type ep16     EPON版本的升法
切换主控板:
ha force-switch
erase    //恢复出厂
show version    //查看版本
show interface ip  //查看三层接口IP信息
show port-mapping   //查看端口
Raisecom#show interface olt 1/2 mac-address-table l2-address //查看MAC
YaoTai6800#show interface epon-olt 1/2 epon-onu mac-address-table l2-address count  //查看onu下在线用户的mac信息
YaoTai6800#show epon-onu 1/1/1 mac-address-table l2-address dynamic  //查看单个onu在线的用户mac
JinShaZhou6800#show mac-address-table l2-address interface epon-olt 1/16  //查看用户的mac
Raisecom#show interface onu online-information  //查看在线ONU信息
Raisecom(fttx)#show running-config fttx full   //运行系统配置信息
XiCun5800E#show interface olt 1/2 transceiver rx-onu-power    //查看onu发光:
liuRong5800#show interface onu 1/2/1-64 transceiver detail   //查看机箱收光
ShuiYin6800#show epon-onu 1/1/9 transceiver                  //查看机箱收光
DaTangFangCao6800#show interface epon-olt 1/15 onu-laser-always-on history  //查看onu是否长发光
TongDeWei6800#show  device   //查看温度
调风扇
HongQiao5800E(fttx)#fan speed mode manual          //先设为手动
HongQiao5800E(fttx)#fan speed manual 35            //再设为35挡
HongQiao5800E(fttx)#show fan                       //查看温度
判断onu长发光方法:自己手动关闭onu,关到那个其他onu上来了就是长发光了。
config
epon-onu  1/1/1
tran  tx-power-supply  primary shutdown  360
查看onu发光:
HAT: High Alarm Threshold,  LAT: Low Alarm Threshold
ONU ID   Monitor Status  Power(dBm)   HAT(dBm)   LAT(dBm)   Alarm Status
1/2/1   disable          -32.2184       8.1647   -40.0000  ok
1/2/2   disable          -27.9588       8.1647   -40.0000  ok
查看pon口发光:
ZhanAn6800(config-if-epon-olt-1:1)#transceiver ddm enable
ZhanAn6800#show interface epon-olt 1/1 ddm detail
                            Current       HAT        HWT        LWT        LAT
    Temperature(℃)         21.5740      100.0000    95.0000     0.0000    -5.0000
    Current(mA)              9.8380      100.0000    80.0000     0.0000     0.0000
    Tx Power(dbm)            4.7190        7.4990     7.0000     2.0000     1.4990
    Rx Power(dbm)          -20.5060       -5.0000    -5.9990   -29.9990   -30.9690
    P3V3 SupplyVoltage(V)    3.2250        3.6000     3.5000     3.1000     3.0000
                            版权声明:本文为博主原创文章,遵循 CC 4.0 BY-SA 版权协议,转载请附上原文出处链接和本声明。
原文链接:https://blog.csdn.net/weixin_41515615/article/details/80959974
GMT+8, 2025-4-22 08:37 , Processed in 0.160468 second(s), 16 queries , Gzip On.
