查看: 4790|回复: 2
[技术讨论] 4/5G互操作 [复制链接]
注册:2021-9-24
发表于 2024-7-10 11:06:37 |显示全部楼层
1,打开移动性开关
MOD NRCELLALGOSWITCH:NRCELLID=1,VOICESTRATEGYSWITCH=EPS_FB_SWITCH-1,INTERRATSERVICEMOBILITYSW=MOBILITY_TO_EUTRAN_SW-1,VONRSWITCH=VONR_SW-0;
2,配置服务小区重选参数,低优先级测量启动门限-110dbm,低优先级重选门限-110dbm,优先级设置为最高7
MOD NRCELLRESELCONFIG:NRCELLID=1,MINIMUMRXLEVEL=-60,CELLRESELPRIORITY=7,NONINTRAFREQMEASRSRPTHLD=5,SERVFREQLOWPRIRSRPRESELTHD=5;
3,配置小区选择门限,最低接收电平-120dbm
MOD NRDUCELLSELCONFIG:NRDUCELLID=1,MINIMUMRXLEVEL=-60;
4,修改gnodeb移动性公共参数
MOD GNBMOBILITYCOMMPARAM:NECHOPREPFAILPUNISHTIMER=20,NONRESHOPREPFAILPUNISHTIMES=10,HOPDUSESSCONFLHANDLINGSW=VOICE_FB_FIRST_SWITCH-1;
5,修改QCI优先级,QCI1:20,QCI2:40,QCI5/6/7/8:90,QCI9:50
MOD GNBQCIBEARER亚星游戏官网-yaxin222CI=1,PRIORITYLEVEL=20;
MOD GNBQCIBEARER亚星游戏官网-yaxin222CI=2,PRIORITYLEVEL=40;
MOD GNBQCIBEARER亚星游戏官网-yaxin222CI=5,PRIORITYLEVEL=90;
MOD GNBQCIBEARER亚星游戏官网-yaxin222CI=6,PRIORITYLEVEL=90;
MOD GNBQCIBEARER亚星游戏官网-yaxin222CI=7,PRIORITYLEVEL=90;
MOD GNBQCIBEARER:QCI=8,PRIORITYLEVEL=90;
MOD GNBQCIBEARER:QCI=9,PRIORITYLEVEL=50;
6,添加4G外部频点,重选优先级配置为:LTE FDD1800M\E频段:3,LTE F频段:2,LTE 其他频段:1;连接态优先级follow重选优先级,低优先级重选门限为-108dbm,理论上现网LTE频点均需添加,此处仅做示例
ADD NRCELLEUTRANNFREQ:NRCELLID=1,DLEARFCN=1300,EUTRANFREQLOWPRIRESELTHLD=10,EUTRANFREQRESELPRIORITY=3,FREQSPECIFICOFFSET=DB0,MEASUREMENTBANDWIDTH=MBW100,MINIMUMRXLEVEL=-64,CONNFREQPRIORITY=3,VOLTEPRIORITY=1;
ADD NRCELLEUTRANNFREQ:NRCELLID=1,DLEARFCN=37900,EUTRANFREQLOWPRIRESELTHLD=10,EUTRANFREQRESELPRIORITY=3,FREQSPECIFICOFFSET=DB0,MEASUREMENTBANDWIDTH=MBW100,MINIMUMRXLEVEL=-64,CONNFREQPRIORITY=3,VOLTEPRIORITY=1;
7,添加4G外部小区
ADD GNBEUTRAEXTERNALCELL:MCC="460",MNC="00",ENODEBID=123456,CELLID=1,DLEARFCN=1300,PHYSICALCELLID=131,TAC=12345;
ADD GNBEUTRAEXTERNALCELL:MCC="460",MNC="00",ENODEBID=123456,CELLID=1,DLEARFCN=37900,PHYSICALCELLID=131,TAC=12345;
8,添加4G邻区
ADD NRCELLEUTRANRELATION:NRCELLID=1,MCC="460",MNC="00",ENODEBID=123456,CELLID=1;
9,修改NR小区异系统切换参数,注意当核心网不支撑切换时,需要把切换开关关掉,同时EPS FB模式修改为重定向,切换事件采用B2事件
MOD NRINTERRATHOPARAM:NRCELLID=1,HOMODESWITCH=EUTRAN_HO_SWITCH-1&EUTRAN_REDIRECT_SWITCH-1&VOICE_BLIND_MODE_SWITCH-0,EPSFBPROTECTIONTIMER=20,INTERRATHOTRIGGEREVENTTYPE=EVENT_B2,EPSFBMODE=HANDOVER;
10,修改NR小区异系统切换测量参数组,异系统A1/A2门限为-105dbm/-110dbm,B2事件门限1 -110dbm,修改之前需要查询现网使用的参数组,使用命令LST NRCELLQCIBEARER:;查询
MOD NRCELLINTERRHOMEAGRP:NRCELLID=1,INTERRATHOMEASGROUPID=0,INTERRATHOA1RSRPTHLD=-105,INTERRATHOA2RSRPTHLD=-110,INTERRATHOA1A2HYST=2,INTERRATHOA1A2TIMETOTRIG=320MS,COVHOTOEUTRANBLINDA2THLD=-115,COVHOTOEUTRANB2RSRPTHLD1=-110;
MOD NRCELLINTERRHOMEAGRP:NRCELLID=1,INTERRATHOMEASGROUPID=1,INTERRATHOA1RSRPTHLD=-105,INTERRATHOA2RSRPTHLD=-110,INTERRATHOA1A2HYST=2,INTERRATHOA1A2TIMETOTRIG=320MS,COVHOTOEUTRANBLINDA2THLD=-115,COVHOTOEUTRANB2RSRPTHLD1=-110;
11,修改NR小区E-UTRAN切换测量参数组,基于覆盖的B1门限为-108dbm,EPS FB的B1门限为-111dbm
MOD NRCELLHOEUTRANMEAGRP:NRCELLID=1,INTERRHOTOEUTRANMEASGRPID=0,COVBASEDHOB1RSRPTHLD=-108,COVBASEDHOB1B2HYST=2,COVBASEDHOB1B2TIMETOTRIG=320MS,EPSFBB1RSRPTHLD=-111,EPSFBB1HYST=2,EPSFBB1TIMETOTRIG=320MS;
MOD NRCELLHOEUTRANMEAGRP:NRCELLID=1,INTERRHOTOEUTRANMEASGRPID=1,COVBASEDHOB1RSRPTHLD=-108,COVBASEDHOB1B2HYST=2,COVBASEDHOB1B2TIMETOTRIG=320MS,EPSFBB1RSRPTHLD=-111,EPSFBB1HYST=2,EPSFBB1TIMETOTRIG=320MS;
12,修改NR小区的异系统切换测量参数组和E-UTRAN切换测量参数组,QCI 1和QCI 2使用参数组0,QCI 3-9使用参数组1
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=1,INTERRATHOMEASGROUPID=0,INTERRHOTOEUTRANMEASGRPID=0;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=2,INTERRATHOMEASGROUPID=0,INTERRHOTOEUTRANMEASGRPID=0;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=3,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=4,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=5,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=6,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=7,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=8,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
MOD NRCELLQCIBEARER:NRCELLID=1,QCI=9,INTERRATHOMEASGROUPID=1,INTERRHOTOEUTRANMEASGRPID=1;
5G SA L2NR互操作参数
前景理论 2022-07-08 17:00 发表于江苏
1、打开到5G移动性开关及快速返回开关
MOD CELLALGOEXTSWITCH亚星游戏官网-yaxin222OCALCELLID=1,HOALLOWEDSWITCH=INTER_RAT_MOBILITY_TO_NR_SW-1&FAST_RETURN_TO_NR_SW-1;
2、打开切换及重定向开关
MOD CELLHOPARACFG亚星游戏官网-yaxin222OCALCELLID=1,HOMODESWITCH=NrRedirectSwitch-1&NrHoSwitch-0,SERVBASEDNRMEASTIMER=10,VOLTEHONRDELAYTIMER=20;
3、修改NR系统切换策略配置,QIC1禁止切换及重定向,2-9打开切换及重定向开关,修改之前需要使用LST QCIPARA查询相应QCI对应的异系统策略配置组ID
MOD INTERRATPOLICYCFGGROUP:INTERRATPOLICYCFGGROUPID=0,NRHOCFG=PS_HO-0&REDIRECTION-0;
MOD INTERRATPOLICYCFGGROUP:INTERRATPOLICYCFGGROUPID=1,NRHOCFG=PS_HO-0&REDIRECTION-1;
MOD INTERRATPOLICYCFGGROUP:INTERRATPOLICYCFGGROUPID=3,NRHOCFG=PS_HO-0&REDIRECTION-1;
4、打开基于业务的基于业务的E-UTRAN切换至NR开关
MOD CELLALGOSWITCH亚星游戏官网-yaxin222OCALCELLID=1,HOALLOWEDSWITCH=ServBasedNrHoSwitch-1;
5、关闭SIB24开关
MOD CELLSIMAP亚星游戏官网-yaxin222OCALCELLID=1,SISWITCH=Sib24Switch-0;
6、增加PLMNLIST,gnb标识长度需要同NR侧保持一致
ADD NCELLPLMNLIST:MCC="460",MNC="00",RATTYPE=NR,PLMNLISTTYPE=WHITE_LIST,GNBIDLENGTH=22;
7、增加NR外部频点,重选优先级7.2,高优先级重选门限-106
ADD NRNFREQ亚星游戏官网-yaxin222OCALCELLID=1,DLARFCN=504990,FREQSPECIFICOFFSET=0,MINRXLEVEL=-60,NRFREQHIGHPRIRESELTHLD=7,NRFREQRESELPRIORITY=7,NRFREQRESELSUBPRIORITY=0DOT_2;
8、增加NR外部小区,NR架构模式需要按照实际情况选择
ADD NREXTERNALCELL:MCC="460",MNC="00",GNODEBID=123456,CELLID=1,DLARFCN=504990,ULARFCNCONFIGIND=NOT_CFG,PHYCELLID=131,TAC=123456,NRNETWORKINGOPTION=SA_NSA;
9、增加NR外部邻区
ADD NRNRELATIONSHIP:LOCALCELLID=1,MCC="460",MNC="00",GNODEBID=123456,CELLID=1;
10、修改NR小区重选定时器
MOD CELLRESELTONR:LOCALCELLID=1,NRCELLRESELECTIONTIMER=1;
11、修改NR异系统公共切换参数组,异系统NR A1/A2门限为-106/-110
MOD INTERRATHOCOMMGROUP:LOCALCELLID=1,INTERRATHOCOMMGROUPID=0,NRB2THLD1RSRP=-110,INTERRATHONRA1THLDRSRP=-106,INTERRATHONRA2THLDRSRP=-110;
ADD INTERRATHOCOMMGROUP:LOCALCELLID=1,INTERRATHOCOMMGROUPID=1,NRB2THLD1RSRP=-110,INTERRATHONRA1THLDRSRP=-106,INTERRATHONRA2THLDRSRP=-110;
12、修改QCI对应的异系统公共切换参数组及异系统切换至NR切换参数组,QCI 1-2使用组0,QCI3-9使用组1
MOD CELLQCIPARA:LOCALCELLID=1,QCI=1,INTERRATHOCOMMGROUPID=0,NRHOPARAMGROUPID=0;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=2,INTERRATHOCOMMGROUPID=0,NRHOPARAMGROUPID=0;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=3,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=4,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=5,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=6,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=7,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=8,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
MOD CELLQCIPARA:LOCALCELLID=1,QCI=9,INTERRATHOCOMMGROUPID=1,NRHOPARAMGROUPID=1;
13、修改NR异系统切换事件为B1事件
MOD INTERRATHOCOMM:INTERRATHONREVENTTYPE=EventB1;
14、修改异系统切换至NR参数组,基于业务及基于覆盖的B1事件门限为-108dbm
MOD INTERRATHONRPARAMGRP:LOCALCELLID=1,NRHOPARAMGROUPID=0,NRB1B2HYSTERESIS=2,NRB1B2TIMETOTRIGGER=512ms,COVBASEDNRB1RSRPTHLD=-108,SERVBASEDNRB1RSRPTHLD=-108;
MOD INTERRATHONRPARAMGRP:LOCALCELLID=1,NRHOPARAMGROUPID=1,NRB1B2HYSTERESIS=2,NRB1B2TIMETOTRIGGER=512ms,COVBASEDNRB1RSRPTHLD=-108,SERVBASEDNRB1RSRPTHLD=-108;
16、修改UE测量控制配置
MOD CELLUEMEASCONTROLCFG:LOCALCELLID=1,MAXNRMEASFREQNUM=4,MEASOPTALGOSWITCH=NSA_SA_MEAS_OBJ_PREEMPTION_SW-1;
17、修改切换公共参数
MOD HOMEASCOMM:NRHORESPREPFAILPENALTYTMR=0;
18、修改基于业务的向NR切换策略配置组ID,1-2使用组1,3-9使用组2
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=1,SERVICEHONRPOLICYGROUPID=0;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=2,SERVICEHONRPOLICYGROUPID=2;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=3,SERVICEHONRPOLICYGROUPID=1;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=4,SERVICEHONRPOLICYGROUPID=2;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=5,SERVICEHONRPOLICYGROUPID=1;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=6,SERVICEHONRPOLICYGROUPID=1;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=7,SERVICEHONRPOLICYGROUPID=1;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=8,SERVICEHONRPOLICYGROUPID=1;
MOD CNOPERATORQCIPARA:CNOPERATORID=0,QCI=9,SERVICEHONRPOLICYGROUPID=1;
19、修改基于业务的向NR切换策略配,QCI 5/6/7/8/9 “MUST_HO”,QCI 1  “NO_HO”
MOD SERVICEIRHOCFGGROUP:CNOPERATORID=0,SERVICEIRHOCFGGROUPID=0,INTERRATHOSTATE=NO_HO;
MOD SERVICEIRHOCFGGROUP:CNOPERATORID=0,SERVICEIRHOCFGGROUPID=1,INTERRATHOSTATE=MUST_HO;
MOD SERVICEIRHOCFGGROUP:CNOPERATORID=0,SERVICEIRHOCFGGROUPID=2,INTERRATHOSTATE=PERMIT_HO;
20、修改基于UE能力的SRVCC切换控制开关
MOD GLOBALPROCSWITCH亚星游戏官网-yaxin222ROTOCOLMSGOPTSWITCH=SRVCCHoBasedUeCapSwitch-1;
GMT+8, 2025-4-4 14:20 , Processed in 0.273151 second(s), 16 queries , Gzip On.
