- 经验
- 61
- 分贝
- 0
- 家园分
- 441
- 208 小时
- 2025-3-8
- 59
- 0
- 2011-3-5
- UID:
- 642204
注册:2011-3-5 2
发表于 2024-6-17 11:25:04
|显示全部楼层
CentOS7多IPsk5服务器一键搭建脚本
#!/bin/bash
PORT_NUM=6666; #端口号
USER_IDX=123456 #用户名的数字起始
START_IP=10 #IIP起始
ADD_COUNT=10 #要添加的数量
IP_PREFIX="192.168.0." #IP的固定部分,记得最后一定要有.
DNS1="100.125.0.250" #主DNS
DNS2="114.114.114.114" #备用DNS
GATEWAY0="192.168.0.1" #网关地址
ACCOUNT_FILE="/root/account.txt" #最后生成的账号文件保存目录
USER_NAME_PREFIX="xx" #用户名的前缀部分,可以为空
creat_password()
local x=abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234356789
#所有密码的可能性是26+26+10=62(0-61是62个数字)
local pass=''
for i in {1..6}
do
num=$[RANDOM%62]
tmp=${x:num:1}
pass=${pass}$tmp
done
echo $pass
function add_ip()
local file_path="/etc/sysconfig/network-scripts/ifcfg-eth0";
chmod 777 $file_path;
local line_str=$(sed -n '/BOOTPROTO/=' $file_path);
if [ -z "$line_str" ]; then
line=-1;
else
line=$line_str;
fi
# echo $line;
if (( line > -1 )); then
echo "${line}c BOOTPROTO=dhpc13";
sed -i "${line}c BOOTPROTO=none" $file_path > /dev/null;
# else
# echo "没有";
fi
for ((i=0; i < ${ADD_COUNT}; i++))
do
sed -i '/^IPADDR/d' $file_path > /dev/null;
done
sed -i '/^PREFIX/d' $file_path > /dev/null;
sed -i '/^GATEWAY/d' $file_path > /dev/null;
sed -i '/^DNS/d' $file_path > /dev/null;
# cat $file_path;
for ((i=0, j=${START_IP}; i < ${ADD_COUNT}; i++, j=j+1))
do
#echo "IPADDR$i=192.168.0.$j";
sed -i '$a'"IPADDR$i=$IP_PREFIX$j" $file_path;
done
sed -i '$aPREFIX0=24' $file_path;
sed -i '$aGATEWAY0='$GATEWAY0 $file_path;
sed -i '$aDNS1='$DNS1 $file_path;
sed -i '$aDNS2='$DNS2 $file_path;
# cat $file_path;
function get_internet_ip()
local accountfile=${ACCOUNT_FILE}
iptables -t mangle -F OUTPUT
for ((i=${START_IP}, j=${USER_IDX}; i < $[ ${START_IP} + ${ADD_COUNT} ]; i++, j=j+1))
do
iptables -t mangle -A OUTPUT -m owner --uid-owner $j -j MARK --set-mark $j
done
iptables -t nat -F POSTROUTING
for ((i=${START_IP}, j=${USER_IDX}; i < $[ ${START_IP} + ${ADD_COUNT} ] ; i++, j=j+1))
do
iptables -t nat -A POSTROUTING -m mark --mark $j -j SNAT --to $IP_PREFIX$i
done
do
# echo "$USER_NAME_PREFIX$j"
ip=$(sudo -u $USER_NAME_PREFIX$j curl ifconfig.me)
# echo "$ip"
sed -i "s/$IP_PREFIX$i/$ip/g" $accountfile > /dev/null
done
install_bbr(){
local path="https://gitee.com/ddsweoerwrw/ss5/raw/master/bbr.sh"
local filename="/root/bbr.sh"
# [ -z "${filename}" ] && filename="$path"
if [ -n "$path" ] && [ ! -f "${filename}" ]; then
wget -q --no-check-certificate ${path} -O ${filename}
fi
# [ -f "${filename}" ] && chmod +x ${filename} && ./${filename}
creat_startSs5_file()
local filename="/root/startSs5.sh";
:> ${filename};
echo 'CURPATH=$(cd "$(dirname "$0")"; pwd) && cd $CURPATH' >> ${filename}
echo 'killall -9 ss5' >> ${filename}
echo 'mkdir /var/run/ss5/' >> ${filename}
echo 'chmod 777 /var/run/ss5/' >> ${filename}
echo 'iptables -t mangle -F OUTPUT' >> ${filename}
echo 'for ((i='${START_IP}', j='${USER_IDX}'; i < '$[ ${START_IP} + ${ADD_COUNT} ]'; i++, j=j+1))' >> ${filename}
echo 'do' >> ${filename}
echo ' iptables -t mangle -A OUTPUT -m owner --uid-owner $j -j MARK --set-mark $j' >> ${filename}
echo 'done' >> ${filename}
echo 'iptables -t nat -F POSTROUTING' >> ${filename}
echo ' iptables -t nat -A POSTROUTING -m mark --mark $j -j SNAT --to '$IP_PREFIX'$i' >> ${filename}
echo ' ss5 -t -m -b '${IP_PREFIX}'$i:'${PORT_NUM}' -u '$USER_NAME_PREFIX'$j' >> ${filename}
echo 'ulimit -SHn 10240' >> ${filename}
echo 'ulimit -SHs unlimited' >> ${filename}
echo 'echo 500000 >/proc/sys/net/nf_conntrack_max' >> ${filename}
creat_user_file()
local filename="/etc/opt/ss5/ss5.passwd";
chmod 777 ${filename}
:> ${filename};
:> ${accountfile}
do
local pw=$(creat_password)
echo "$USER_NAME_PREFIX$j $pw" >> ${filename}
echo "$IP_PREFIX$i/$PORT_NUM/$USER_NAME_PREFIX$j/$pw" >> ${accountfile}
done
update_ss5_conf_file()
local filename="/etc/opt/ss5/ss5.conf";
sed -i '/^auth/d' ${filename} > /dev/null;
echo 'auth 0.0.0.0/0 - u' >> ${filename}
sed -i '/^permit/d' ${filename} > /dev/null;
echo 'permit u 0.0.0.0/0 - 0.0.0.0/0 - - - - -' >> ${filename}
install_new()
install_bbr
creat_startSs5_file
if [ ! -f "/root/ss5-3.8.9-8.tar.gz" ];then
wget -q --no-check https://gitee.com/ddsweoerwrw/ss5/raw/master/ss5-3.8.9-8.tar.gz
fi
chmod 777 /root/bbr.sh && /root/bbr.sh && sysctl net.ipv4.tcp_available_congestion_control && sysctl net.ipv4.tcp_congestion_control
yum -y install gcc openldap-devel pam-devel openssl-devel
yum -y install psmisc
tar -vzx -f ss5-3.8.9-8.tar.gz && cd ss5-3.8.9/ && ./configure && make && make install && chmod a+x /etc/init.d/ss5
add_ip
creat_user_file
##添加用户
do
/usr/sbin/useradd $USER_NAME_PREFIX$j -u $j -M -s /dev/null
done
chmod 777 /etc/rc.d/rc.local
chmod 777 /root/startSs5.sh
#写入自启文件
echo "/root/startSs5.sh" >> /etc/rc.d/rc.local
#将公网IP写入account.txt
get_internet_ip
cat "/root/account.txt"
reboot
install_new
