查看: 3610|回复: 2
ma5608t 配置 [复制链接]
亚星游戏官网-yaxin222  上等兵
注册:2011-3-52
发表于 2024-2-24 00:59:20 |显示全部楼层
[Saving user: NMS]
[Saving time: 2015-12-20 04:52:22+08:00]
[MA5600V800R013: 5900]
[sysmode]
  <sysmode>
switch adsl mode to rfc2662 vdsl mode to tr129
xpon mode switch-to profile-mode
voice-spec set vag-num 8
voice-spec set sip-account-num 2048
protocol support h248
system ex-mode backup
router mode basic
[global-config]
  <global-config>
sysname NC-LZ-JYGHF-OLT.MA5608-01
terminal user name buildrun_new_password root *JJB+Y)<-a*_I>V@/60YR=Y(5!* 7 0000:00:00:00:00:00 2015:12:07:14:45:22 root 1 "-----"
terminal user name history_password root *JJIa&C9`=]1-"Z3`MK/QGO75!*
traffic table ip index 7 name " DEFAULT_SCOS3_CCOS3" cir off priority 3 inner-priority 3 priority-policy local-setting
traffic table ip index 8 name "DEFAULT_NOCOS" cir off priority 0 priority-policy local-setting
traffic table ip index 9 name "DEFAULT_SCOS5_CCOS5" cir off priority 5 inner-priority 5 priority-policy local-setting
traffic table ip index 10 name "DEFAULT_SCOS6_CCOS6" cir off priority 6 inner-priority 6 priority-policy local-setting
traffic table ip index 11 name "DEFAULT_SCOS3_CCOS3" cir off priority 3 inner-priority 3 priority-policy local-setting
trap filter event condition id 0x0a300013
trap filter event condition id 0x0a300015
resource threshold mem 94
dba-profile add profile-id 10 profile-name "LANXTELX-GZ" type3 assure 4096 max 10240
dba-profile add profile-id 11 profile-name "FTTH-100M" type3 assure 10240 max 133120
dba-profile add profile-id 12 profile-name "FTTH-10M" type3 assure 4096 max 10240
dba-profile add profile-id 14 profile-name "LANXTELX-ZQ" type3 assure 10240 max 512000
dba-profile add profile-id 15 profile-name "TEST" type3 assure 30016 max 49984
dba-profile add profile-id 16 profile-name "100M-ZQ" type3 assure 51200 max 102400
ont-alarm-policy policy-id 1 policy-name "LANXTELX"
  alarm append ip-address mac loid
  alarm filter 0x2e112001
  alarm filter 0x2e112002
  alarm filter 0x2e112003
  alarm filter 0x2e112004
  alarm filter 0x2e112006
  alarm filter 0x2e112009
  alarm filter 0x2e11200a
  alarm filter 0x2e11999e
  alarm filter 0x2e11999f
  alarm filter 0x2e11a009
  alarm filter 0x2e11a00a
  alarm filter 0x2e11a00b
  alarm filter 0x2e11a00c
  alarm filter 0x2e11a00f
  alarm filter 0x2e11a104
  alarm filter 0x2e11a107
  alarm filter 0x2e11a524
  alarm filter 0x2e305015
  alarm filter 0x2e30501a
  alarm filter 0x2e30a10d
  alarm filter 0x2e30a10e
  alarm filter 0x2e313015
  alarm filter 0x2e313016
  alarm filter 0x2e313017
  alarm filter 0x2e313018
  alarm filter 0x2e313019
  alarm filter 0x2e31301a
  alarm filter 0x2e313024
  alarm filter 0x2e313025
  alarm filter 0x2e31302a
  alarm filter 0x2e31999b
  alarm filter 0x2e31999d
  alarm filter 0x3f010008
  alarm filter 0x3f010009
  alarm filter 0x3f01000a
  alarm filter 0x60110008
  alarm filter 0x6011a603
  alarm filter 0x6011a604
  alarm filter 0x6030a019
  alarm filter 0x6030a01a
  alarm filter 0x60311011
  alarm filter 0x6031a033
  commit
ont-srvprofile epon profile-id 1 profile-name "F460"
  ont-port pots 2 eth 4
  multicast fast-leave enable
  ring check enable
  commit
ont-srvprofile epon profile-id 2 profile-name "HG810e"
  ont-port eth 4
  ring check enable
  commit
ont-srvprofile epon profile-id 3 profile-name "HG8245"
  commit
ont-srvprofile epon profile-id 4 profile-name "HG8245_4LAN_2POTS"
  port vlan eth 1 43
  port vlan eth 2 43
  port vlan eth 3 43
  port vlan eth 4 45
  port multicast-vlan eth 4 51
  commit
ont-srvprofile epon profile-id 5 profile-name "LAN2TEL1"
  ont-port pots 1 eth 2
  ring check enable
  commit
ont-srvprofile epon profile-id 6 profile-name "LAN4TEL2"
  ring check enable
  commit
ont-srvprofile epon profile-id 10 profile-name "LANXTELX-SRV"
  ont-port pots adaptive eth adaptive
  ring check enable
  commit
ont-lineprofile epon profile-id 10 profile-name "LANXTELX-GZ"
  fec enable
  llid dba-profile-id 10
  llid encrypt triple-churning
  undo llid ont-car
  commit
ont-lineprofile gpon profile-id 0 profile-name "line-profile_default_0"
  tcont 0 dba-profile-id 2
  tcont 1 dba-profile-id 0
  commit
  quit
[device-config]
  <device-config>
board add 0/0 H808EPSD
board add 0/1 H808EPSD
board add 0/4 H801MPWD
board add standby sub0 CPCB
[public-config]
  <public-config>
snmp-agent local-engineid 800007DB03001882A0C19D
snmp-agent community read %!G$E+J57F>LR1Y@KKG%YB1!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent community write %H.UF'S`%86)WE+H_^O1;@1!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent sys-info contact HW-075528780808
snmp-agent sys-info location Shenzhen_China
snmp-agent target-host trap-hostname traphost.huawei.10.2.97.254 address 10.2.97.254 udp-port 162 trap-paramsname traphost.huawei.10.2.97.254
snmp-agent target-host trap-paramsname huawei v2C securityname %GKJ_#W##T#^EQX`]X#XOPQ!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent target-host trap-paramsname traphost.huawei.10.2.97.254 v2C securityname %H.UF'S`%86)WE+H_^O1;@1!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent trap enable standard
snmp-profile add profile-id 50 profile-name "snmp-profile_50" v1 "%!G$E+J57F>LR1Y@KKG%YB1!!B#A8&)VAB']]F;U$19'2_1!!%" "%H.UF'S`%86)WE+H_^O1;@1!!B#A8&)VAB']]F;U$19'2_1!!%" 10.2.97.254 162 "%'[^(<8[Q65FC=@'W=)VGT1!!B#A8&)VAB']]F;U$19'2_1!!%"
[vlan-config]
  <vlan-config>
vlan 2163 to 2164 smart
vlan 2363 to 2364 smart
vlan 2563 to 2564 smart
vlan 2763 to 2764 smart
vlan 3970 smart
vlan 3990 smart
vlan 4010 smart
vlan attrib 2163 to 2164 q-in-q
vlan attrib 2363 to 2364 q-in-q
vlan attrib 2563 to 2564 stacking
vlan attrib 2763 to 2764 q-in-q
port vlan 2163 to 2164 0/2 0
port vlan 2363 to 2364 0/2 0
port vlan 2563 to 2564 0/2 0
port vlan 2763 to 2764 0/2 0
port vlan 3970 0/2 0
port vlan 3990 0/2 0
port vlan 4010 0/2 0
[mcu]
  <mcu-0/2>
interface mcu 0/2
speed 0 1000
speed 1 1000
speed 2 1000
speed 3 1000
[epon]
  <epon-0/0>
interface epon 0/0
port 0 ont-auto-find enable
port 1 ont-auto-find enable
port 2 ont-auto-find enable
port 3 ont-auto-find enable
port 4 ont-auto-find enable
port 5 ont-auto-find enable
port 6 ont-auto-find enable
port 7 ont-auto-find enable
  <epon-0/1>
interface epon 0/1
[emu-config]
  <emu-config>
emu add 0 fan 0 1  "H831FCBB"
emu add 1 h801pmu 0 0  "H801PMUB"
[qos-config]
  <qos-config>
queue-scheduler wrr 10 3 3 10 3 70 1 0
[btv-config]
  <btv-config>
btv
igmp bandwidthCAC disable
btv
igmp user add service-port 72 no-auth
igmp user add service-port 73 no-auth
igmp user add service-port 74 no-auth
multicast-vlan 3990
  igmp version v2
  igmp multicast-vlan member service-port-list 72-74
  igmp mode proxy
  igmp program add batch start-index 0 ip 239.93.16.1 to-ip 239.93.17.254
  igmp uplink-port 0/2/0
[dhcp-config]
  <dhcp-config>
dhcp option82 enable
[config]
  <config>
mpls label start 8192
[prevlanif]
  <prevlanif>
interface vlanif3970
interface vlanif4010
[vlanif]
  <vlanif3970>
ip address 10.3.9.74 255.255.255.252
  <vlanif4010>
ip address 2.68.4.146 255.255.255.0
[meth]
  <meth0>
interface meth0
ip address 10.11.104.2 255.255.255.0
[null]
  <null0>
interface null0
[aaa]
  <aaa>
aaa
authentication-scheme "default"
authorization-scheme "default"
accounting-scheme "default"
domain "default"
return
GMT+8, 2025-4-22 05:27 , Processed in 0.236910 second(s), 15 queries , Gzip On.
