亚星游戏官网-yaxin222  列兵
注册:2012-4-21
发表于 2023-12-19 09:30:54 |显示全部楼层
MA5620的sip电话,下面是完整配,不知道那里有问题不通,有哪位高手给指点一下那里错了,谢谢。
(10.0.0.31是设备管理地址,10.0.0.253是sip服务器地址。10.0.0.254是网关8018,8002是电话号码)
MA5620#display    current-configuration
{ <cr>|port<K>|section<K>|service-port<K>|simple<K>||<K> }:
  Command:
[MA5620V800R312: 2300]
[sysmode]
  <sysmode>
protocol support sip
[device-config]
  <device-config>
port port-index 0/0/1 port-type GPON-PORT
[public-config]
  <public-config>
snmp-agent local-engineid 800007DB03F898B9BF22380C
snmp-agent community read %S0O&R^7OW*+Xa9W4YQ.U=1!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent community write %0;OY:ZN9E3#]`FQ^XRO$#A!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent target-host trap-hostname 1MTU.10.0.0.250 address 10.0.0.250
udp-port 162 trap-paramsname 1MTU.10.0.0.250
snmp-agent target-host trap-paramsname 1MTU.10.0.0.250 v1 securityname %S0O&R^ 7OW*+Xa9W4YQ.U=1!!B#A8&)VAB']]F;U$19'2_1!!%
snmp-agent trap enable standard
[vlan-config]
  <vlan-config>
vlan 103 smart
protocol-8021p-pri 5 vlan 103
port vlan 103 0/0 1
[gponnni]
  <gponnni-0/0/1>
interface gponnni 0/0/1
password "%5L3_.^M^.9I\5<V@WN#JI1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'
2_1!!%"
loid "%VL*&O__.3U3;RaK'0`"NPQ!!,DWUN(I=,'UZ_`@1RI<=WQ!!%"
checkcode "%L9;7+FT2-[LX3NU/Va@a]Q!!%"
[voip]
  <voip>
voip
ip address media 10.0.0.31 10.0.0.254
ip address signaling 10.0.0.31
[sip]
  <sip-0>
interface sip 0
if-sip attribute basic media-ip 10.0.0.31 signal-ip 10.0.0.31 signal-port 5060
if-sip attribute basic primary-proxy-ip1 10.0.0.253 primary-proxy-port 5060
if-sip attribute basic sipprofile-index 0
[esl-user]
  <esl-user>
esl user
sippstnuser add 0/2/1 0 telno 8018
sippstnuser add 0/2/2 0 telno 8002
sippstnuser attribute set 0/2/1 dc-time 80
sippstnuser attribute set 0/2/2 dc-time 80
sippstnuser rightflag set 0/2/1 telno 8018 cw disable
sippstnuser rightflag set 0/2/2 telno 8002 cw disable
sippstnuser auth set 0/2/1 telno 8018  auth-username "%IG\E.5@=,`N3+\.1WE8A!A!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!%"
sippstnuser auth set 0/2/1 telno 8018  password-mode password auth-password %:
5&@5=D'%[]ZVS]'aTOGQ!!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)
VAB']]F;U$19'2_1!!%
sippstnuser auth set 0/2/2 telno 8002  auth-username "%$]!``"#DDLJ&8W"XG<"PD1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!%"
sippstnuser auth set 0/2/2 telno 8002  password-mode password auth-password %
BUDK<FT7`E)HI&V7[#+D8!!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)VAB']]F;U$19'2_1!!B#A8&)
VAB']]F;U$19'2_1!!%
[prevlanif]
  <prevlanif>
interface vlanif103
[vlanif]
  <vlanif103>
interface vlanif103
ip address 10.0.0.31 255.255.0.0
[meth]
  <meth0>
interface meth0
ip address 10.11.104.2 255.255.255.0
[null]
  <null0>
interface null0
[aaa]
  <aaa>
aaa
authentication-scheme "default"
authorization-scheme "default"
accounting-scheme "default"
domain "default"
[post-system]
  <post-system>
ip route-static 10.0.0.253 255.255.255.255 vlanif103 10.0.0.254
return
MA5620#
GMT+8, 2025-4-22 11:32 , Processed in 0.307972 second(s), 15 queries , Gzip On.
