查看: 3866|回复: 2
[FTTx/PON] MA5620语音配置 [复制链接]
注册:2023-9-22
发表于 2023-12-1 09:02:12 |显示全部楼层
MA5620(config)#display current-configuration
{ <cr>|section<K>|simple<K>||<K> }:
  命令:
[MA5620V800R312: 3900]
[global-config]
  <global-config>
resource threshold mem 85
system parameters 3 2
[device-config]
  <device-config>
port port-index 0/0/1 port-type GPON-PORT
[public-config]
  <public-config>
snmp-agent local-engineid 800007DB03707BE8595A9501
snmp-agent community read "%0+\.YNY:!R4[=8"E>6.a$A!!B#A8&)VAB']]F;U$19'2_1!!%"
snmp-agent community write "%UX/<0a5YW8*亚星游戏官网-yaxin222AQ\4SECNQ!!B#A8&)VAB']]F;U$19'2_1!!%"
snmp-agent sys-info version v2c
[vlan-config]
  <vlan-config>
vlan 46 smart
vlan 51 smart
vlan 53 smart
vlan 55 smart
port vlan 46 0/0 1
port vlan 51 0/0 1
port vlan 53 0/0 1
port vlan 55 0/0 1
protocol-8021p-pri 5 vlan 46
[vlan-srvprof]
  <vlan-srvprof>
vlan service-profile profile-id 1 profile-name "srvprof-1"
  packet-policy multicast forward
  user-bridging enable
  commit
vlan bind service-profile 46 profile-id 1
vlan bind service-profile 51 profile-id 1
vlan bind service-profile 53 profile-id 1
vlan bind service-profile 55 profile-id 1
[gponnni]
  <gponnni-0/0/1>
interface gponnni 0/0/1
password "%5L3_.^M^.9I\5<V@WN#JI1!!%"
loid "%VL*&O__.3U3;RaK'0`"NPQ!!,DWUN(I=,'UZ_`@1RI<=WQ!!%"
checkcode "%L9;7+FT2-[LX3NU/Va@a]Q!!%"
[emu-config]
  <emu-config>
emu add 0 h831vesc 0 1 RS232 "H831VESC"
[bbs-config]
  <bbs-config>
service-port 0 vlan 51 eth 0/1/1 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 1 vlan 51 eth 0/1/2 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 2 vlan 51 eth 0/1/3 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 3 vlan 51 eth 0/1/4 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 4 vlan 51 eth 0/1/5 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 5 vlan 51 eth 0/1/6 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 6 vlan 55 eth 0/1/13 multi-service user-vlan untagged  rx-cttr 6  tx-cttr 6
service-port 7 vlan 55 eth 0/1/14 multi-service user-vlan untagged  rx-cttr 6
tx-cttr 6
service-port 8 vlan 46 eth 0/1/15 multi-service user-vlan untagged  rx-cttr 6  tx-cttr 6
service-port 9 vlan 51 eth 0/1/16 multi-service user-vlan 51  rx-cttr 6 tx-cttr 6
service-port 10 vlan 53 eth 0/1/16 multi-service user-vlan 53  rx-cttr 6
tx-cttr 6
service-port 11 vlan 55 eth 0/1/16 multi-service user-vlan 55  rx-cttr 6
tx-cttr 6
service-port 12 vlan 53 eth 0/1/7 multi-service user-vlan untagged  rx-cttr 6  tx-cttr 6
service-port 13 vlan 53 eth 0/1/8 multi-service user-vlan untagged  rx-cttr 6  tx-cttr 6
service-port 14 vlan 53 eth 0/1/9 multi-service user-vlan untagged  rx-cttr 6  tx-cttr 6
service-port 15 vlan 53 eth 0/1/10 multi-service user-vlan untagged  rx-cttr 6 tx-cttr 6
service-port 16 vlan 53 eth 0/1/11 multi-service user-vlan untagged  rx-cttr 6 tx-cttr 6
service-port 17 vlan 53 eth 0/1/12 multi-service user-vlan untagged  rx-cttr 6 tx-cttr 6
[abs-config]
  <abs-config>
config
[voip]
  <voip>
voip
ip address media 10.10.55.200 10.10.55.1
ip address signaling 10.10.55.200
qos vlan media 10.10.55.200 priority 0
[sip]
  <sip-0>
interface sip 0
if-sip attribute basic media-ip 10.10.55.200 signal-ip 10.10.55.200 signal-port 5060
if-sip attribute basic primary-proxy-ip1 10.10.55.2 primary-proxy-port 5060
[esl-user]
  <esl-user>
esl user
sippstnuser add 0/2/1 0 telno 2010
sippstnuser add 0/2/2 0 telno 2011
sippstnuser add 0/2/3 0 telno 2012
sippstnuser attribute set 0/2/1 dc-time 80
sippstnuser attribute set 0/2/2 dc-time 80
sippstnuser attribute set 0/2/3 dc-time 80
sippstnuser rightflag set 0/2/1 telno 2010 cw disable
sippstnuser rightflag set 0/2/2 telno 2011 cw disable
sippstnuser rightflag set 0/2/3 telno 2012 cw disable
sippstnuser auth set 0/2/1 telno 2010  auth-username "2010"
sippstnuser auth set 0/2/1 telno 2010  password-mode password auth-password *
SXR;M!@X`07Q=^Q`MAF4<1!!*
sippstnuser auth set 0/2/2 telno 2011  auth-username "2011"
sippstnuser auth set 0/2/2 telno 2011  password-mode password auth-password */ LPR";`MU!'Q=^Q`MAF4<1!!*
sippstnuser auth set 0/2/3 telno 2012  auth-username -
sippstnuser auth set 0/2/3 telno 2012  password-mode password auth-password *9.Ia[MQ>OT[Q=^Q`MAF4<1!!*
[prevlanif]
  <prevlanif>
interface vlanif46
interface vlanif55
[vlanif]
  <vlanif46>
interface vlanif46
ip address 192.168.46.201 255.255.255.0
  <vlanif55>
interface vlanif55
ip address 10.10.55.200 255.255.255.0
[meth]
  <meth0>
interface meth0
ip address 10.11.104.2 255.255.255.0
[null]
  <null0>
interface null0
[aaa]
  <aaa>
aaa
authentication-scheme "default"
authorization-scheme "default"
accounting-scheme "default"
domain "default"
return
GMT+8, 2025-4-22 14:52 , Processed in 0.200231 second(s), 15 queries , Gzip On.
