亚星游戏官网-yaxin222  一级通信军士
注册:2022-9-252
发表于 2023-10-10 14:58:43 |显示全部楼层
# ls www
total 720
-rwxrwxrwx    1 root     root         36512 Oct  4  2017 JSON.php
-rwxrwxrwx    1 root     root          4631 Oct  4  2017 PHPTelnet.php
drwxrwxrwx    2 root     root           320 Oct  4  2017 Scripts
drwxrwxrwx    2 root     root           784 Oct  4  2017 access_user_manage
drwxrwxrwx    2 root     root          1360 Oct  4  2017 audit_monitor
-rwxrwxrwx    1 root     root           881 Oct  4  2017 audit_monitor_left.php
drwxrwxrwx    2 root     root           616 Oct  4  2017 awifi
-rwxrwxrwx    1 root     root           764 Oct  4  2017 awifi_left.php
-rwxrwxrwx    1 root     root          1927 Oct  4  2017 center.php
-rwxrwxrwx    1 root     root          6712 Oct  4  2017 change_pwd.php
-rwxrwxrwx    1 root     root           521 Oct  4  2017 checkauthcount.php
-rwxrwxrwx    1 root     root           879 Oct  4  2017 checktime.php
-rwxrwxrwx    1 root     root           875 Oct  4  2017 clienthint.js
drwxrwxrwx    2 root     root           680 Oct  4  2017 css
-rwxrwxrwx    1 root     root          1062 Oct  4  2017 ct_left.php
-rwxrwxrwx    1 root     root        164178 Oct  4  2017 ct_wizard0.php
-rwxrwxrwx    1 root     root         48906 Oct  4  2017 ct_wizard0_bridge.php
-rwxrwxrwx    1 root     root         36250 Oct  4  2017 ct_wizard0_route.php
drwxrwxrwx    4 root     root           312 Oct  4  2017 custom
drwxrwxrwx    2 root     root           304 Oct  4  2017 debug
-rwxrwxrwx    1 root     root          1798 Oct  4  2017 device_show.php
drwxrwxrwx    2 root     root           232 Oct  4  2017 diagnostics
-rwxrwxrwx    1 root     root           927 Oct  4  2017 diagnostics_left.php
-rwxrwxrwx    1 root     root           873 Oct  4  2017 down.php
-rwxrwxrwx    1 root     root           506 Oct  4  2017 down_list.php
-rwxrwxrwx    1 root     root          5897 Oct  4  2017 err_page.php
-rwxrwxrwx    1 root     root           685 Oct  4  2017 filedown_tst.php
drwxrwxrwx    2 root     root          5336 Oct  4  2017 firwall
-rwxrwxrwx    1 root     root          2095 Oct  4  2017 ftp_tst.php
-rwxrwxrwx    1 root     root          1018 Oct  4  2017 gethint.php
-rwxrwxrwx    1 root     root          1097 Oct  4  2017 guish_tst.php
-rwxrwxrwx    1 root     root          3762 Oct  4  2017 hotad_push.php
drwxrwxrwx   10 root     root          8248 Oct  4  2017 images
drwxrwxrwx    2 root     root          2448 Oct  4  2017 inface
-rwxrwxrwx    1 root     root           918 Oct  4  2017 interface_left.php
-rwxrwxrwx    1 root     root            55 Oct  4  2017 issue.net
drwxrwxrwx    2 root     root           232 Oct  4  2017 itms
drwxrwxrwx    6 root     root          1656 Oct  4  2017 js_script
-rwxrwxrwx    1 root     root         11680 Oct  4  2017 left.php
drwxrwxrwx    3 root     root           968 Oct  4  2017 lib
drwxrwxrwx    2 root     root           232 Oct  4  2017 log
-rwxrwxrwx    1 root     root         15236 Oct  4  2017 login.php
-rwxrwxrwx    1 root     root          2278 Oct  4  2017 main.php
-rwxrwxrwx    1 root     root          5168 Oct  4  2017 mkdir_usb.php
-rwxrwxrwx    1 root     root          7434 Oct  4  2017 modify_passwd.php
-rwxrwxrwx    1 root     root           670 Oct  4  2017 my_remote_debug.php
-rwxrwxrwx    1 root     root          1253 Oct  4  2017 mylogin.sh
drwxrwxrwx    2 root     root          2824 Oct  4  2017 network
drwxrwxrwx    2 root     root          8168 Oct  4  2017 php_class
-rwxrwxrwx    1 root     root         18752 Oct  4  2017 plupload.flash.swf
-rwxrwxrwx    1 root     root           979 Oct  4  2017 port_mod.php
drwxrwxrwx    2 root     root           560 Oct  4  2017 portal_auth
drwxrwxrwx    4 root     root           288 Oct  4  2017 public
drwxrwxrwx    2 root     root          1840 Oct  4  2017 remote_manage
drwxrwxrwx    2 root     root          3232 Oct  4  2017 router
-rwxrwxrwx    1 root     root           885 Oct  4  2017 save.php
-rwxrwxrwx    1 root     root          5802 Oct  4  2017 save_usb.php
drwxrwxrwx    2 root     root          2848 Oct  4  2017 security
-rwxrwxrwx    1 root     root          2368 Oct  4  2017 show_telnet.php
-rwxrwxrwx    1 root     root          4841 Oct  4  2017 snmp_auth_login.php
-rwxrwxrwx    1 root     root          4088 Oct  4  2017 soap_dhcp.php
-rwxrwxrwx    1 root     root           345 Oct  4  2017 stat.php
-rwxrwxrwx    1 root     root           921 Oct  4  2017 sys_left.php
drwxrwxrwx    3 root     root          3856 Oct  4  2017 sys_manager
-rwxrwxrwx    1 root     root           961 Oct  4  2017 sysmngr_left.php
drwxrwxrwt    4 root     root           120 Oct  9 03:11 tmp
-rwxrwxrwx    1 root     root          7577 Oct  4  2017 top.php
-rwxrwxrwx    1 root     root          1441 Oct  4  2017 top_operation.php
-rwxrwxrwx    1 root     root         22952 Oct  4  2017 tr069_auth_login.php
-rwxrwxrwx    1 root     root          6303 Oct  4  2017 tr069_auth_login_snpasswd.php
-rwxrwxrwx    1 root     root          1948 Oct  4  2017 upload.php
-rwxrwxrwx    1 root     root          3031 Oct  4  2017 upload_blackfile.php
-rwxrwxrwx    1 root     root          2944 Oct  4  2017 upload_boot_main.php
-rwxrwxrwx    1 root     root         29036 Oct  4  2017 upload_cfg.swf
-rwxrwxrwx    1 root     root         29061 Oct  4  2017 upload_cfg_en.swf
-rwxrwxrwx    1 root     root           825 Oct  4  2017 upload_ipslib.php
-rwxrwxrwx    1 root     root           841 Oct  4  2017 upload_netaction.php
-rwxrwxrwx    1 root     root          2658 Oct  4  2017 upload_sfmig.php
-rwxrwxrwx    1 root     root          3295 Oct  4  2017 upload_sfmig_back.php
-rwxrwxrwx    1 root     root          3414 Oct  4  2017 upload_sfmig_main.php
-rwxrwxrwx    1 root     root          3036 Oct  4  2017 upload_sysconfig.php
-rwxrwxrwx    1 root     root          7629 Oct  4  2017 upload_usb.php
-rwxrwxrwx    1 root     root          3092 Oct  4  2017 upload_whitefile.php
-rwxrwxrwx    1 root     root           926 Oct  4  2017 urlfilter_left.php
-rwxrwxrwx    1 root     root          5219 Oct  4  2017 usb_content.php
-rwxrwxrwx    1 root     root          6289 Oct  4  2017 usb_top.php
-rwxrwxrwx    1 root     root          7881 Oct  4  2017 usblogin.php
-rwxrwxrwx    1 root     root           738 Oct  4  2017 usbmain.php
drwxrwxrwx    2 root     root           464 Oct  4  2017 user
-rwxrwxrwx    1 root     root           925 Oct  4  2017 voip_left.php
drwxrwxrwx    2 root     root          3400 Oct  4  2017 voip_manager
-rwxrwxrwx    1 root     root           304 Oct  4  2017 voip_register_operation.php
drwxrwxrwx    2 root     root          4744 Oct  4  2017 vpn
-rwxrwxrwx    1 root     root          7550 Oct  4  2017 web_auth_login.php
-rwxrwxrwx    1 root     root          5437 Oct  4  2017 web_auth_login1.php
-rwxrwxrwx    1 root     root          1769 Oct  4  2017 web_auth_logout_success.php
-rwxrwxrwx    1 root     root           682 Oct  4  2017 wifidog-msg.html
# ls www/sys_manager
total 456
-rwxrwxrwx    1 root     root          5111 Oct  4  2017 audit_monitor_cfg.php
-rwxrwxrwx    1 root     root          8923 Oct  4  2017 backupsettings.php
drwxrwxrwx    3 root     root           736 Oct  4  2017 chart
-rwxrwxrwx    1 root     root          9096 Oct  4  2017 flow_log_manager.php
-rwxrwxrwx    1 root     root          6077 Oct  4  2017 flow_stat_log.php
-rwxrwxrwx    1 root     root          1946 Oct  4  2017 flow_stat_table_detail.php
-rwxrwxrwx    1 root     root         17430 Oct  4  2017 ftp_serv_config.php
-rwxrwxrwx    1 root     root          2640 Oct  4  2017 get_stat_data.php
-rwxrwxrwx    1 root     root         10584 Oct  4  2017 gzzd_dnsquery.php
-rwxrwxrwx    1 root     root         11446 Oct  4  2017 gzzd_httpget.php
-rwxrwxrwx    1 root     root          2876 Oct  4  2017 gzzd_inform.php
-rwxrwxrwx    1 root     root         15624 Oct  4  2017 gzzd_mod.php
-rwxrwxrwx    1 root     root         11893 Oct  4  2017 gzzd_tcp.php
-rwxrwxrwx    1 root     root         11771 Oct  4  2017 gzzd_traceroute.php
-rwxrwxrwx    1 root     root          2112 Oct  4  2017 history_flow_stat_table_detail.php
-rwxrwxrwx    1 root     root          3921 Oct  4  2017 hostname_mod.php
-rwxrwxrwx    1 root     root          8351 Oct  4  2017 intout.php
-rwxrwxrwx    1 root     root          3142 Oct  4  2017 intsettings.php
-rwxrwxrwx    1 root     root          2451 Oct  4  2017 list_audit_monitor_switch.php
-rwxrwxrwx    1 root     root          4577 Oct  4  2017 list_capture.php
-rwxrwxrwx    1 root     root          5639 Oct  4  2017 list_debug.php
-rwxrwxrwx    1 root     root          4419 Oct  4  2017 list_history_stat.php
-rwxrwxrwx    1 root     root          9347 Oct  4  2017 list_mailcfg.php
-rwxrwxrwx    1 root     root         36396 Oct  4  2017 list_manager_stat_log.php
-rwxrwxrwx    1 root     root         11896 Oct  4  2017 list_session.php
-rwxrwxrwx    1 root     root          9005 Oct  4  2017 list_stat_audit.php
-rwxrwxrwx    1 root     root          7041 Oct  4  2017 list_stat_log.php
-rwxrwxrwx    1 root     root         26519 Oct  4  2017 list_status.php
-rwxrwxrwx    1 root     root          1427 Oct  4  2017 list_temp_blocking_policy.php
-rwxrwxrwx    1 root     root          2286 Oct  4  2017 list_traffic_monitor.php
-rwxrwxrwx    1 root     root          8387 Oct  4  2017 manager_stat_log.php
-rwxrwxrwx    1 root     root           748 Oct  4  2017 more_3G.php
-rwxrwxrwx    1 root     root           879 Oct  4  2017 more_4G.php
-rwxrwxrwx    1 root     root          1168 Oct  4  2017 ping_data.php
-rwxrwxrwx    1 root     root          4360 Oct  4  2017 protocol_manage_add.php
-rwxrwxrwx    1 root     root          4243 Oct  4  2017 protocol_manage_mod.php
-rwxrwxrwx    1 root     root          2087 Oct  4  2017 session_stat_detail.php
-rwxrwxrwx    1 root     root          7918 Oct  4  2017 sf_update_mod.php
-rwxrwxrwx    1 root     root         11678 Oct  4  2017 smart_softupgrade.php
-rwxrwxrwx    1 root     root         13294 Oct  4  2017 sntpcfg.php
-rwxrwxrwx    1 root     root          9731 Oct  4  2017 softupdate.php
-rwxrwxrwx    1 root     root          6955 Oct  4  2017 sys_config_mod.php
-rwxrwxrwx    1 root     root         14177 Oct  4  2017 sysreboot_mod.php
-rwxrwxrwx    1 root     root         10903 Oct  4  2017 temp_blocking_policy_add.php
-rwxrwxrwx    1 root     root          9023 Oct  4  2017 time_mod.php
-rwxrwxrwx    1 root     root          4176 Oct  4  2017 updatesetting.php
-rwxrwxrwx    1 root     root           465 Oct  4  2017 upload_tst.php
本帖有 4 个回帖,您需要登录后才能浏览 登录 | 注册
GMT+8, 2025-4-22 14:36 , Processed in 0.431147 second(s), 16 queries , Gzip On.
