查看: 5248|回复: 1
[App编程/平台开发] [转帖]银河学院教程——Linux入门10(转帖) [复制链接]
亚星游戏官网-yaxin222  上等兵
注册:2007-6-11
发表于 2007-6-11 14:13:00 |显示全部楼层
<p><span style="FONT-SIZE: 9pt;"><font face="宋体">实行中的命令<span lang="EN-US">
                                        <p></p></span></font></span></p><p><span style="FONT-SIZE: 9pt;"><font face="宋体">在<span lang="EN-US">more</span>命令的实行过程中,用户可以使用<span lang="EN-US">more</span>自己的一系列命令动态地根据需要来选择显示的部分。<span lang="EN-US">more</span>在显示完一屏内容之后,将停下来等待用户输入某个命令。下表列出了<span lang="EN-US">more</span>指令在实行中用到的一些常用命令,而有关这些命令的完整内容,可以在<span lang="EN-US">more</span>实行时按<span lang="EN-US">h</span>查看。这些命令的实行方法是先输入<span lang="EN-US">i</span>(行数)的值,再打所要的命令,不然它会以预设值来实行命令。<span lang="EN-US">
                                        <p></p></span></font></span></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">空格 若指定<span lang="EN-US">i</span>,显示下面的<span lang="EN-US">i</span>行;否则,显示下一整屏。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">回车 若指定<span lang="EN-US">i</span>,显示下面的<span lang="EN-US">i</span>行;否则,显示下一行。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">ù<span lang="EN-US"> D </span>按,若指定<span lang="EN-US">i</span>,显示下面的<span lang="EN-US">i</span>行;否则,往下显示半屏(一般为<span lang="EN-US">11</span>行)。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">id </span><span style="FONT-SIZE: 9pt;">同<span lang="EN-US">i</span>ù<span lang="EN-US"> D </span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">iz </span><span style="FONT-SIZE: 9pt;">同“<span lang="EN-US">i</span>空格”类似,只是<span lang="EN-US">i</span>将成为以下每个满屏的缺省行数。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">is </span><span style="FONT-SIZE: 9pt;">跳过下面的<span lang="EN-US">i</span>行再显示一个整屏。预设值为<span lang="EN-US">1</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">if </span><span style="FONT-SIZE: 9pt;">跳过下面的<span lang="EN-US">i</span>屏再显示一个整屏。预设值为<span lang="EN-US">1</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">ù<span lang="EN-US"> B </span>按,往回跳过(即向文件首回跳)<span lang="EN-US">i</span>屏,再显示一个满屏。预设值为<span lang="EN-US">1</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">b </span><span style="FONT-SIZE: 9pt;">与<span lang="EN-US">i</span>ù<span lang="EN-US"> B</span>相同。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><span style="FONT-SIZE: 9pt;"><font face="宋体">’ 回到上次搜索的地方 <span lang="EN-US">
                                        <p></p></span></font></span></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">q</span><span style="FONT-SIZE: 9pt;">或<span lang="EN-US">Q </span>退出<span lang="EN-US">more</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><span style="FONT-SIZE: 9pt;"><font face="宋体">= 显示当前行号。<span lang="EN-US">
                                        <p></p></span></font></span></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">v </span><span style="FONT-SIZE: 9pt;">在当前行启动<span lang="EN-US">/usr/bin/vi</span>对之进行编辑修改。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">h </span><span style="FONT-SIZE: 9pt;">显示各命令的帮助信息。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i/pattern </span><span style="FONT-SIZE: 9pt;">查找匹配该模式的第<span lang="EN-US">i</span>行。预设值为<span lang="EN-US">1</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">in </span><span style="FONT-SIZE: 9pt;">查找符合表达式的倒数<span lang="EN-US">i</span>行。预设值为<span lang="EN-US">1</span>。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">! </span><span style="FONT-SIZE: 9pt;">或 :<span lang="EN-US">! </span>在子<span lang="EN-US">shell</span>中实行命令。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">:<span lang="EN-US">n </span>在命令行中指定了多个文件名的情况下,可用此命令使之显示第<span lang="EN-US">i</span>个文件,若<span lang="EN-US">i</span>过大(出界),则显示文件名列表中的最后一个文件。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">:<span lang="EN-US">p </span>在命令行中指定了多个文件名的情况下,可用此命令使之显示倒数第<span lang="EN-US">i</span>个文件。若<span lang="EN-US">i</span>过大(出界),则显示第一个文件。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">i</span><span style="FONT-SIZE: 9pt;">:<span lang="EN-US">f </span>显示当前文件的文件名和行数。<span lang="EN-US">
                                        <p></p></span></span></font></p><p><span style="FONT-SIZE: 9pt;"><font face="宋体">· 重复上次键人的命令。<span lang="EN-US">
                                        <p></p></span></font></span></p><p><span style="FONT-SIZE: 9pt;"><font face="宋体">例<span lang="EN-US">1</span>:用分页的方式显示一个文件的内容。<span lang="EN-US">
                                        <p></p></span></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">$ more example1.c <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/*-------------------------------------------*/ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/* example1.c */ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/*-------------------------------------------*/ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/* author f opus.BBS@BBS.cs.nthu.edu.tw */ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/* target f BBS main/login/top-menu routines */ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/* create f 99/10/23 */ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/* update f 99/12/15 */ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">/*-------------------------------------------*/ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">#define _MAIN_C_ <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">#inc1ude &lt; BBS. h &gt; <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">jmp_buf byebye; <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">int talkrequest=NA; <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">static uschar Enter_uflag i <p></p></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><font face="宋体">#ifdef SHOW_IDLE_TIME <p></p></font></span></p><p><font face="宋体"><span lang="EN-US" style="FONT-SIZE: 9pt;">--More- </span><span style="FONT-SIZE: 9pt;">(<span lang="EN-US">3%</span>) <span lang="EN-US"><p></p></span></span></font></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><p><font face="宋体">&nbsp;</font></p></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><p><font face="宋体">&nbsp;</font></p></span></p><p style="MARGIN-BOTTOM: 0pt; TEXT-INDENT: 17.85pt;"><span style="FONT-SIZE: 9pt;"><font face="宋体">本文转自:<span lang="EN-US"><a href="http://www.newstu.org/">www.newstu.org</a></span>   银河学院新大学教育<span lang="EN-US">N.C.E</span>计划<span lang="EN-US"><p></p></span></font></span></p><p style="MARGIN-BOTTOM: 0pt; TEXT-INDENT: 17.85pt;"><span style="FONT-SIZE: 9pt;"><font face="宋体">咨询热线:<span lang="EN-US">027-51788877</span>    咨询<span lang="EN-US">Q Q:495492526</span> <span lang="EN-US">731330728<p></p></span></font></span></p><p style="MARGIN-BOTTOM: 0pt; TEXT-INDENT: 17.85pt;"><span style="FONT-SIZE: 9pt;"><font face="宋体">咨询<span lang="EN-US">Email:yinheedu509@163.com</span>学院地址:武汉市洪山区武珞路<span lang="EN-US">720</span>号<span lang="EN-US"><p></p></span></font></span></p><p><span lang="EN-US" style="FONT-SIZE: 9pt;"><p><font face="宋体">&nbsp;</font></p></span></p>
GMT+8, 2024-11-23 09:52 , Processed in 0.337507 second(s), 16 queries , Gzip On.
