查看: 4760|回复: 1
[电源] [原创]以太网供电POE模块 [复制链接]
亚星游戏官网-yaxin222  一级军士长
注册:2003-6-272
发表于 2007-4-20 13:36:00 |显示全部楼层
<p>The Ag9000-S series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet (PoE) standard.<br/>IEEE 802.3af allows for two power options for Category 5 cables and the Ag9000-S series have two pairs of power inputs pins: - VA1&amp;2 and VB1&amp;2 to accommodate this, see Figure 1.<br/>The Ag9000-S signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The Ag9000 is compatible with Class 0 to Class 3 equipment.<br/>The high efficiency DC/DC converter operates over a wide input voltage range and provides a regulated low ripple and low noise output. The DC/DC converter also has built-in overload and short-circuit output protection.</p><p><a href="mailto:Jacky@walasey.com">Jacky@walasey.com</a></p><p>0755-83295597</p>
GMT+8, 2024-11-23 08:56 , Processed in 0.081822 second(s), 15 queries , Gzip On.
