查看: 1593|回复: 1
[技术讨论] PRB资源块的对数 [复制链接]
注册:2020-3-27
发表于 2021-11-23 20:29:22 |显示全部楼层
numberPRB-Pairs
Indicates the number of physical resource-block pairs used for the EPDCCH set. Value n2 corresponds to 2 physical
resource-block pairs; n4 corresponds to 4 physical resource-block pairs and so on. Value n8 is not supported if dl-
Bandwidth is set to 6 resource blocks. EUTRAN only configures values up to n6 for BL UEs or UEs in CE. Value n6 is
only applicable to BL UEs or UEs in CE
PRB: physical resource-block pairs 代表资源块的对数,两个RB为1对,n2代表两对资源块
RB: 资源块
注意两者的区别。
GMT+8, 2024-11-15 13:44 , Processed in 0.218482 second(s), 15 queries , Gzip On.
