亚星游戏官网-yaxin222  上等兵
注册:2005-12-2
发表于 2006-1-6 16:22:00 |显示全部楼层
G.841(10/98)关于这个问题有两段论述,我给看糊涂了,谁给讲讲:
第一段话:(第3页)
dedicated protection: A protection architecture that provides capacity dedicated to the protection of traffic-carrying capacity (1 + 1). See Recommendation G.803.
第二段话:(第26页)
Linear VC trail protection is a dedicated protection mechanism that can be used on any physical structure (i.e. meshed, ring, or mixed). It may be applied in any path layer in a layered network.
It is an end-to-end protection mechanism, and switches on server failures and client level information, including path performance information. It need not be used on all VCs within a multiplex section.
Linear VC trail protection switching can operate in a unidirectional or bidirectional manner. Bidirectional protection switching has the ability to carry extra traffic on the protection path.
第一段话说只有1+1是专用保护,第二段第一句说线性VC通道保护是专用保护,最后一句又说保护通道可以传额外业务,应该就是说可以是1:1的了,谁给说明一下!
还有一个问题,我一直以为VC级的保护都是1+1的,这里怎么好像说还可以是1:1的,以前看到说VC4/3的K3字节和VC12的K4字节可以用作APS保护,实际中有这样用的吗?
本帖有 7 个回帖,您需要登录后才能浏览 登录 | 注册
GMT+8, 2024-11-25 16:45 , Processed in 0.098264 second(s), 16 queries , Gzip On.
